Tube & Pipe parameters
I have made my own Tube & Pipe Styles with my own parts.
My problem is that the format of the parameter PL (Pipe Lenght) change from value without unit (ex. "100") to value with unit (ex. "100 mm") for pipes I creating by populate a route in Tube & Pipe Environment.
PL parameter for the template that Tube & Pipe are using.
PL parameter for the created pipe in Tube & Pipe Environment.
It works fine when I create a pipe direct from Content Center but when Tube & Pipe doing it it changes some of the parameters and PL get its unit that I don´t want.
The reason I don´t want the unit after the value is that I want the length without unit in the parts list on my drawing. I use the parameter PL in Dimension property under Custom iProperties. And then the parts list template use the Dimension property as shown in picture below.
Correct parts list, the length 200 without unit. This works when I create direct from Content Center.
Wrong parts list, the length 200 with unit. This fails when the pipe is created in Tube & Pipe Environment.
Does anyone have a solution or workaround for this issue?
Many thanks!
