Inventor Forum
Tube & Pipe Missing from Environment Tab
7 REPLIES 7
Message 1 of 8
nrio924798RQH
276 Views, 7 Replies
nrio924798RQH
Tube & Pipe missing from environment tab. How do I install tube & pipe manually? I have Inventor Professional 2025 currently installed.
7 REPLIES 7
Message 2 of 8
Gabriel_Watson
Check under tools > add-ins if the module is loaded:
Message 3 of 8
RajSchmidt
in reply to: nrio924798RQH
RajSchmidt
You have opened a part. Tube & Pipe is only available in the assembly environment…
Message 4 of 8
blandb
blandb
You are in a part file.
Autodesk Certified Professional
Message 5 of 8
nrio924798RQH
in reply to: blandb
nrio924798RQH
Yes, I was in a part file.
Message 6 of 8
nrio924798RQH
yes box is checked
yes box is checked
Message 7 of 8
nrio924798RQH
I've created an assembly, but I'm having trouble initiating a pipe run. When I attempt to start it, nothing happens and the pipe ribbon doesn't appear. Any advice on how to initiate a pipe run or the conditions that need to be met?
Message 8 of 8
johnsonshiue
Hi! This could be an install issue. Or your system does not allow Inventor to access certain files. Try a few things. Please make sure all critical Windows updates are installed and the graphics driver is updated. Install the latest Inventor update to your Inventor version.
Right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run As Admin."
If it still does not work, go to Control Panel -> System -> Advanced System Settings -> Environment Variables -> create "DYNAMIC_LOAD_APPLETS" and set it to 0. Restart Inventor.
Does it work better now?
Many thanks!
Software Test Engineer
Many thanks!
