- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This seems like if should be really simple, but im having problems.
Basically, I want to be able to have two sketches, top and bottom, with a parameter that sets the distance between them, then loft between them to make a tapered "shell". I'd then put a bottom on it to make a box.
The problem im having is that the loft command wont let me pick the profile i need. It either picks the entire rectangle, or the inner shape, not the profile that would make it a hollow box with a tapered wall.
Ive attached pictures of what im trying to do... I managed to get what i want by just extruding up a full box, then lofting out the middle, but this is by far the simplest of a long line of these. Some have extra geometry in the walls, tapered inside and out, etc. It would be much simpler if it was made up of two sketches connected by a loft. Is it really not possible to do it like that?
