Trying to create a drop down list in iProperties using Parameter Multi Value
This widget could not be displayed.
I have found a number of solutions that are close to what I need, but here's what I'm trying to accomplish.
I am trying to create a drop down list in the Stock Number field in iProperties, of (5) pipe sizes that we commonly use. This will keep it simple and consistent for the engineers.
They are more familiar with Parameters and iProperties, so I am trying to avoid looking for/using iLogic Forms, Rules and xls.
The end result will be, they open iProperties, navigate to Stock Number and select from the drop down list.
Thanks for any help.
mcgyvr
Having a dropdown there is not possible at all AFAIK..
What is possible is ilogic code (form) to allow them to select from a list to populate that field though from a dropdown list...
But thats ilogic which you wanted to avoid..
I had actually seen that solution, tried it, and it worked fine.
Seeing as I can't do the other, I'll go with it.
Thanks for the confirmation.
