Truncated Cone Development
MikeKovacik4928
Advisor Advisor
Message 1 of 10
MikeKovacik4928
Hi all inventor users world wide.
I'm sure lots of you have already done this many times before
I need you to share with me how you develop a truncated cone using inventor sheet metal.
In the days before computers, on the drawing board, I used to do this from first principles.
I have long ago forgotten that, and could look it up again in my old books and notes.
However there is no point these days, as the software now does everything for you, you no longer
have to think or know first principles!!
See attached. How would I flat pattern this?
Mike Kovacik
Inventor Pro 2018
South Africa
Replies (9)
Message 2 of 10
mcgyvr
Quite a few youtube videos/tutorials on the subject..
https://www.youtube.com/watch?v=N-dX2qd3rCQ
Message 3 of 10
JDMather
@MikeKovacik4928 wrote:
...you no longer have to think or know first principles!!
You do to pass my classes. 🎓
1st principle, the edges should be perpendicular to the flat (yours are not).
One of the 4 rules of sheet metal.
Message 4 of 10
johnsonshiue
Hi Mike,
This case should have been done using Lofted Flange -> Rip. Or, Loft (surface) -> Thicken -> Rip. The Solid Loft may not yield the perfect geometry required to unfold.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Message 5 of 10
karthur1
Mike Kovacik
Inventor Pro 2018
South Africa
There are several ways you can model this.  Revolved a surface, Thickened, then generated the flat.  If you do not revolve the full 360°, then you do not have to split it.
Kirk
Message 6 of 10
MikeKovacik4928
Amazingly easy when you know how and have done it before!!
Mike
Message 7 of 10
MikeKovacik4928
I cannot open your file, it is a newer version of Inventor than I am using (Inventor 2018).
I have however discovered how do it now.
Mike
Message 8 of 10
MikeKovacik4928
I see what you are talking about, I will bear that in mind in the future.
What are the other 3 rules?
Mike
Message 9 of 10
MikeKovacik4928
Thanks Johnson
I see that now
Thanks to all for your replies.
Mike
Message 10 of 10
JDMather
1. Sheet metal is uniform Thickness
2. Bends are cylindrical or conical (except for Lofted Flange)
3. Cuts are perpendicular to the flat.
4. Flange faces are planar (except for Lofted Flange)
5. Flanges cannot intersect in folded or flat
6. In general, model in finished form rather than folding from flat.
https://www.youtube.com/watch?v=BAa6J0Pigp0
