Trouble with draft
Trouble with draft
drspringer
Message 1 of 8
Trouble with draft
drspringer
I need to add 2 degrees draft to the vertical walls of the top cylinder on this insert. When I try I get a weird curved surface.
We want the draft to come from the angled diameter so when it is molded the hole looks like a circle.
Can anyone help?
Thank you.
Replies (7)
Message 2 of 8
JDMather
The size of that file is rather astonishing?
I think I would remodel from scratch.
The attached file is a bit smaller size.
Message 3 of 8
drspringer
I tried rebuilding it but ended up with the same thing. I referenced the angled surfaces from the original file.
Message 4 of 8
kgilham
It looks like you have discovered a defect with our draft tool.  I will be logging this and seeing what our development team can do to fix this issue.
Kyle Gilham
Customer Advocacy Manager
Message 5 of 8
drspringer
That's great but can anyone think of a way around it so I can get this job done?
Message 6 of 8
JDMather
I am having trouble determining your design intent.
Can you do a hand sketch and attach it here.
I am sure there is a way (with Revolve or Loft), but I am not sure what you want.
Message 7 of 8
drspringer
I just figured it out as the last message came in. Loft was the correct answer. I split the bottom angled face with the larger diameter and used loft to connect the two. Add in my chamfer and I'm done. Thanks for the brain push.
Randy
Message 8 of 8
wilkhui
Hi Randy - thanks for reporting the 'weird curved surface', we worked out that the problem is in the graphics and we're trying to fix it (for reference this is logged as ASM-4147).
This means that the surface is actually fine but it just looks a bit weird as .ipt - if you create a drawing view everything looks ok:
Hope this helps to clear up some of the confusion..!
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
