Can't find a way to chamfe/radius a face
ToddPig
Message 1 of 11
ToddPig
I would like to select a face, either a flat surface, or a cylinder, and have a chamfer/radius placed at every edge of this surface.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Replies (10)
Message 2 of 11
Curtis_Waguespack
Hi ToddPig,
For a radius have a look at the Rule Fillet tool. Nothing is coming to mind for chamfers though.
You might need to enable the Plastic Part panel to find it.
On the ribbon, click 3D Model tab  >  Show Panel icon . Select Plastic Part panel to display the Plastic Part panel, and then select Rule Fillet
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
I hope this helps.
Curtis
Message 3 of 11
ToddPig
That's a good trick. Thanks. Do you have one for chamfer?
Inventor 2018
iParts = iHeadache
Message 4 of 11
Cadmanto
Todd,
There is a way to select faces, but not the way you are describing.  In the fillet command you can pick one face and then an adjacent one, but that is cumbersome.  You can also select a feature and it will radius all edges that way, but not a face as you describe.  This looks to be a good candidate for the Inventor IdeaStation
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or i you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 11
JDMather
A face is bounded by a Loop, so if you set the selection to Loop and click the edge of face at loop.
Message 6 of 11
ToddPig
Awesome, thanks JD.
Any ideas for applying a chamfer in the same manner.
For example, I have holes thru a part, and would like to select the cylindrical surface, and have the same chamfer applied to each side of the hole.
Inventor 2018
iParts = iHeadache
Message 7 of 11
Curtis_Waguespack
Hi ToddPig,
I have a trick to do that, but it's customization. I don't know of a way to do it otherwise.
Maybe it would be a good Idea Forum post:
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
This iLogic creates a chamfer on already chamfered edges, which is shouldn't do, but I didn't bother trying to filter those out.
Use at your risk!
I hope this helps.
Curtis
oSize = InputBox("Enter a size for the chamfer", "iLogic", "")
If oSize = "" Then
Return
oDoc = ThisDoc.Document
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oFace As face
' define the edge collection.
oEdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection
'Keep Selecting Faces, Hit Esc to finish
Do
	oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face (Press ESC to exit)")
	If Not oFace Is Nothing Then
		' Add all of the edges of the face to the edge collection.
		For Each oEdge In oFace.Edges
			oEdgeCollection.Add (oEdge)
		Next
		Dim oChamfer As ChamferFeature
		Try
		oChamfer = oCompDef.Features.ChamferFeatures.AddUsingDistance(oEdgeCollection, oSize)
		Catch
			MessageBox.Show("Chamfer could not be created.", "iLogic")
		End Try
Loop While Not oFace Is Nothing
Message 8 of 11
mcgyvr
Just another thing..
If the edges are tangent then if you have the "All tangentially connected edges" (expand the >> for that option in the chamfer dialog) selected and the shape applies then it will select the loop
And yes.. If you select "Distance/Angle" you can select whole faces too..
Message 9 of 11
ToddPig
very cool. might be more work than selecting all the edges, but still impressive.
Inventor 2018
iParts = iHeadache
Message 10 of 11
ToddPig
The "Distance/Angle" does not really work, it only chamfers a single edge.
Inventor 2018
iParts = iHeadache
Message 11 of 11
mcgyvr
Oh yeah.. Sorry about that.. It worked for me because I had that "tangentially" option selected..
I didn't try it on a "non-tangential" area when I tried that..
oops...
