Trouble Unfolding This Part
Hi everyone, this part has me stumped, I was hoping somebody could have a go at unfolding it for me.  This is a 2016 part.  Thanks in advance.
JDMather
The part is not modeled correctly.
A bent part, must of course, have bends.
If those planar faces are supposed to be tangent - the original file would make it easer to correct (rather than a derived part).
And cuts should be perpendicular to the flat.  (Just like in the real world.)
Let's not quibble over semantics, there is a bend, albeit one large one across the whole part.  Although there isn't an actual feature labelled Bend or Flange, the part is showing the design intent.  I was hoping there would be a simple operation that could be performed that would enable the creation of a flat pattern, but it looks like that isn't the case.
I don't know how you came to the conclusion that the faces aren't tangent, because they are.  That line is there because I operate mostly in the Shaded with Edges visual style.
I've included the original part.  Hopefully that will be enough for you to give a decent look at it.
JDMather
First thing that I noticed is that your first sketch was not fully constrained (and too complex).
Maybe something like this is what you are after.
Thanks for taking a look.  After looking at the second part I sent you I realize the sketch is definitely unconstrained.  That was a result of me pulling that particular feature out of a multi-solid body and it lost some of its references.  It's debatable whether or not it is too complex.
You're part is exactly what I was after.  While I was waiting I also came up with another method.  Are there any major problems with the way I did this one?
