Hi there,
I tried to run the Sample standalone applicatiuons in VC++, when I compiled SimpleExe.cpp, the compiler tells that
fatal error C1083: Cannot open type library file: 'RxInventor.tlb': No such file or directory
Isn't RxInventor.tlb supposed to be built in the directory? Or else in this case how can I get the library into the right position?
Thank you,
Difan
yes I did.
Just search "RxInventor" In the installation folder of Inventor, then copy the file to the SimpleExe folder.
