Thanks all,
I may have to make it from scratch as Mark says, but it is beyond me why these simple things do not function properly.
@Mark.Lancaster@: The spur gear does not accept the diameter I need and I cannot scale it up. Perhaps I do not understand the interface well enough, but I was not able to generate the gear I need. The spur gear should work in sketch and modelling, IMHO.
@JDMather: About 4 m diameter in this case. Pressure Angle: 20. Teeth 29. Pitch Diameter: 3.739 m Diametral Pitch: 0.197 Attached is a photo of one of the gear generators I tried, but could not create a gear with.
@Anonymous : I was exported from Maya. Attached is a dxf output from a gear generator. Thanks for the workaround, but it seems very heavy.
>After having the basic shape, make a derived part of it with scale factor 100 or 10.
I was not aware of this capability. I can make a derived part for a spur gear?
Overall, this process has been very frustrating. Simple things that should just work, don't, and there is no indicator as why. Coupled with capabilities that come and go, depending on the mode, is a real headache. I want to be able to select and delete a piece in every mode. I know what I want to accomplish and spend a huge amount of time fighting the interface to get what I need. All pieces should be created in the same place, not scattered around in different sections.
After 15 years of development, I would think Inventor would be much easier to use and would do simple things without effort. What I am trying to do is trivial and should "just work".
/rant
