I am trying to draw a bowl that is made of staves (like a barrel). I have drawn an individual stave as a part and a base plate on which to assemble the parts. I placed a single stave onto the base plate constraining one vertex to be on top of the base plate. I then made a circular pattern of 16 staves. I can move or free rotate my original stave and do an update to get things close to where I want them.
I would like to add a constraint that adjacent sides must be touching. This should pull all the staves together so they touch. There should then be one degree of freedom left of the stave is tilted and I'd like to be able to adjust that by hand.
The problem is it won't let me constrain two adjacent sides to be touching. I suspect this is because they are in a pattern.
I could laboriously place one stave at a time (not using a pattern) and apply the constraints, but that is tedious at best and also doesn't let me easily change number of staves.
I've attached a zip file of my design files in the hopes that someone can help me.
Of lesser importance, if someone can tell me how to color every other stave a different color, I would appreciate it.
