Inventor Forum
Welcome to Autodeskโ€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Triaxial ellipsoid, DirectEdit fail
4 REPLIES 4
revyakin
524 Views, 4 Replies
Hi all,
I am trying to create a triaxial ellipsoid (a sphere squashed/stretched along 3 axes). Therefore,
I created a sketch and made an ellipse in the XY plane.
I drew a line across the Y axis and trimmed it to create a half-ellipse.
I revolved it along the Y axis and got a rotationally symmetrical ellipsoid (like one would get in a lathe).
I then tried to 'squash' it along the X axis by scaling non-uniformly by 0.5.
AI showed me the desired shape during preview, but then showed an error message saying DirectEdit failed. No further information. I observed this kind of behaviour with other features as well (i.e. the preview showing the desired result, but then failing w/o further explanation when the tool applied).
I have attached my IPT file, if it helps at all. Tried to locate the log, but failed... for now at least ๐Ÿ˜ž
Autodesk Professional 2016 Student Edition, W7 Pro
4 REPLIES 4
WHolzwarth
in reply to: revyakin
That's been caused by an inaccurate sketch for the ellipse.
2016 file attached
Walter Holzwarth
revyakin
in reply to: WHolzwarth
Hi Walter,
Thanks a lot for responding. I cannot open the file in my 2016 AI, I need to reinstall the newer build, did not get around to doing it yet.
May I ask to briefly point out what was imprecise in my sketch? I thought it was 'just an ellipse', but I may be wrong
JDMather
Line does not have a vertical constraint.
Line does not have coincident constraint between midpoint and origin.
Ellipse does not have a coincident constraint between centerpoint and origin.
Missing two size defining dimensions.
WHolzwarth
in reply to: JDMather
Oh, oh. I've added the 2018 file before. Now 2016
Walter Holzwarth
