Inventor Forum
Transparent Building in Render
8 REPLIES 8
Message 1 of 9
CD-Magnox
519 Views, 8 Replies
I have an assembly consisting of a building and a facility inside.
I am trying to render an image with the building in transparent but the facility normal.
When ever I go into render no matter what I do the building will not be transparent.
I have tried making my building a single part with a transparent appearance assigned to it, this doesn't work, setting transparency in the model tree doesn't work.
Does anyone know a work around for this?
I'm running Inventor 2021.
8 REPLIES 8
Message 2 of 9
mcgyvr
in reply to: CD-Magnox
How specifically is it not working?
Can you show us some images to help better understand the problem?
Message 3 of 9
CD-Magnox
in reply to: mcgyvr
The building in rendering as a normal building, not as a transparent building.
Message 4 of 9
CD-Magnox
Ok I am limited in what I can show, but as you can see the inventor image shows building as transparent, the second image shows the render view with the buildings normal.
Message 5 of 9
SharkDesign
Your parts are not transparent which is why they don't render that way.
You need to apply a transparent appearance from the drop down menu at the very top of your screen.
Using any other transparent option won't work.
You can also do this by setting up a view rep called something like 'transparent' in your assembly, using that override the parts with a to transparent appearance.
That way you can use that view rep to render and user the master view rep to show it normally coloured.
  Expert Elite
  Inventor Certified Professional
Message 6 of 9
SharkDesign
Hopefully this video explains it. Sorry the audio is quiet, the kids are in bed!
https://knowledge.autodesk.com/community/screencast/84934e70-b22b-492a-b4ae-1f169e2c4389
  Expert Elite
Message 7 of 9
CD-Magnox
in reply to: SharkDesign
Many thanks that has worked, one other question is how do I get a sharper image of the internals of my buildings?
I can now see the internals through the buildings however the image isn't sharp?
Message 8 of 9
SharkDesign
Maybe try changing the refraction setting in the appearance? Or changing
the amount of transparency or glossy. The tool tip explains how glossy
works.
  Expert Elite
Message 9 of 9
CD-Magnox
Excellent thanks for your help
