Transparent Background
Message 1 of 14
I have sheetmetal parts i export image to .png file for a company broshure. Right now i have a white background with shadows. How do i make the background transparent before exporting 3D image? Here is what it looks like now. I am having a hard time finding it under application options/ colors.
Replies (13)
Message 2 of 14
alewer
If you render the image with Studio, you can save as a .png with alpha channel.  I'm on 2010 so I am not sure if this is an option using "Save Copy As" in 2011 or 2012.
Message 3 of 14
RonnieWilkins
It's no different for 2011 or 2012
Ronnie Wilkins, Jr.
Message 4 of 14
johnsonshiue
Hi! Here is how you change document background.
In Inventor, go to Tools -> Application Options -> Colors -> Background -> Background image and point to a transparent "colored" image file.
Thanks!
Software Test Engineer
Message 5 of 14
RonnieWilkins
That does not work, at least in 2012
Ronnie Wilkins, Jr.
Message 6 of 14
RonnieWilkins
Here is how it can be done.
Forgot to mention...
Save As Type must be set to PNG or another image type that supports Alpha Channels.
Bitmap (.bmp) files do not support alpha channels.
Ronnie Wilkins, Jr.
Message 7 of 14
Edited and Merged by
Discussion_Admin
Message 8 of 14
mcgyvr
Of what? Open the png file in your photoediting tool of choice (photoshop,etc..) use the magic wand to remove the background and save as png
Edited by
Discussion_Admin
Message 9 of 14
Curtis_W
Hi freestyle4x4f150,
Here's a tip from Mark Flayler on out putting a PNG with a transparent background from Studio:
http://blogs.rand.com/manufacturing/2010/01/inventomizations-image-export-options.html
Also, your blank post is likely a result of a setting in IE9. If you set it to Compatibility Mode, it should fix it:
http://support.microsoft.com/kb/956197
I hope this helps.
Curtis
http://inventortrenches.blogspot.com/
Edited by
Discussion_Admin
Message 10 of 14
Where do I find a transparent colors image?
Message 11 of 14
Here you go.
Message 12 of 14
subhro.p.dutta
best way will be to publish in PNG , transfer to Photoshop , then background Transparency
Message 13 of 14
matthew
As an addon to this is there a way to create a wall that will also output as an alpha channel so that only the shadows are captured in the render. Allowing the shadows to be usable in any background?
Message 14 of 14
spl1970
Going back to the original question (doesn't answer the question about shadows being captured), unless I'm missing something..
File -> Export -> Image
