Transitional surface constraints
b_ruijter
b_ruijter
Trasitional constraints are giving me a headache. Ive made a slot and some pins to a dish to simulate movement.
 But as you can see in the attached video the pin pops out of the slot and on the external surface?!
What am i doing wrong here?
Xun.Zhang
Hello @b_ruijter,
Try to apply the Contact Analysis for a better result.
Set the pin as contact set and make sure the solver is active.
Thanks!
Xun
johnsonshiue
Hi! I have seen this behavior before. There is a trick you can play which can help stabilize the solve. Open the rail parts which contain the stationary faces. Create a zero-distance offset surface on the stationary faces. Then extend the surface both ways to provide enough coverage. Go back to the assembly and edit the transitional constraints. Change the stationary faces to the offset surfaces.
Although transitional constraint, requires two face selection, the transitional motion can happen between any faces on the two participant components. By changing the stationary face to the surface body, the transitional motion is then limited to the offset surface body. Please try it out and see if it works better.
Many thanks!
Software Test Engineer
