Trace the center of gravity of an assembly using dynamic simulation
I am trying to trace the position of the COG for a mechanism using the dynamic simulation.
I know someone made a post about this before but I had a hard time following the thread.
I also know that I could record the coordinate locations of the center of gravity and plot the points but that will take far too long and I am kind of tired of doing that way.
I am not familiar with ilogic and if that is the only way to do I will probably need help to implement the code
I am familiar with VBA though.
Here is what I am trying to do:
I am driving the angle of the lower left corner and I would like to trace the center of gravity for a full rotation
Thanks for your time.
JDMather
Cite the prior reference.
Attach assembly here.
Here is the other post: https://forums.autodesk.com/t5/inventor-customization/tracing-the-center-of-gravity-of-assembly-in-a...
This file has been edited with counter balances but you can just remove them as the COG wont change with them there
