Top Down and adaptive sketch's with Inventor
Hi Folks
I use Inventor and Solidworks (Freelance Engineer), and I'm looking to start taking a more top down approach to my modelling. With solidworks this is relatively straight forward (if a little crashy), as for the most part, the references do what you expect. With Inventor I'm finding references between sketch's don't see to update properly. As a hypothetical example, if I was drawing a machine, and was specifically drawing the base frame, and I wanted to use a master sketch on the first level of the assembly to determine the overall size of the baseframe, then on the second level of the assembly (baseframe weldment), I wanted to use a second sketch that referenced the 1st level master sketch, to determine the over all size, and I also add in all the crossmembers and other features at this level. The goal here is that if I change the primary master sketch, all the other components throughout the assembly will update to reflect this change, I.e. if I shorten the base frame by 100mm in the master, the baseframe weldment will also update to take this change. At the moment, when I create my reference geometry it does not update correctly when I make changes. Is there a setting somewhere I'm missing, and I was also curios whats best practice here?
