Title block won't update
Message 1 of 23
The title block in my drawnig won't update, nor allow me to change manually.
I replaced the refernce model from another drawing, but I have done this before without nay complications.
How can I force this to change?
Replies (22)
Message 21 of 23
That sounds like an area which I need to know. How do you change where the drawing get the information from? i.e. model vs custom
Message 22 of 23
mdavis22569
Edit the title block text ....
and if you look at all of the pictures I've attached this shows you ..
check out this video ..get to the 20 minute range and it'll show you about setting up the properties
https://www.youtube.com/watch?v=a8BOXQenA9A
Mike Davis
Message 23 of 23
mcgyvr
mtofts...
Are you clear on all this now?
The title block was simply setup to pull the title from a custom iproperty "title" in the drawing itself..
Not the model title or even the drawing file title (normal properties).
This custom field was empty hence the "title" was empty also..
If thats not how you want it (and assuming you are the one in charge of drawings/procedures at your company) then you may want to redo your titleblocks/templates to pull from where you want it..
