Title block won't update
Message 1 of 23
The title block in my drawnig won't update, nor allow me to change manually.
I replaced the refernce model from another drawing, but I have done this before without nay complications.
How can I force this to change?
Replies (22)
Message 2 of 23
mdavis22569
Can you share the IDW ..
Are you pulling the properties from the Model instead of the Drawing?
We can't tell here they are being populated from ... we know you have a pop up box that you populate ....but that's it
Mike Davis
Message 3 of 23
I am pulling them from a model, but the document iproperties are correct there. Everything seems correct.
I had an issue with this the other day because I was using tables, and the information was being pulled from one of the parts. I managed to sort it by changing the part name, but this still didn't answer my concern:
Where does this information come from, and how can I interact/rectify with it?
Message 4 of 23
mdavis22569
Well if you have the pop up in your idw, you'll want to pull it from there.  however you can pull it from the ipt/iam as well .... I only made the comment because of the pop up in the idw
I'm opening the idw now
Mike Davis
Message 5 of 23
Ray_Feiler
Have you tried closing down Inventor and opening it back up?
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 6 of 23
mdavis22569
I didn't have a problem
are you looking at your iproperties?
I was able to fill it right from the iproperties ...that's where they are all located
Mike Davis
Message 7 of 23
mcgyvr
The "title" field is set to grab the custom iproperty named "title" from the drawing.. That field is empty in your drawing.. So naturally its empty..
Message 8 of 23
mdavis22569
your title block is set up to fill all of it from your iproperties custom page
Mike Davis
Message 9 of 23
Ok, that is a start. If I get stuck I can manually change it. Thanks.
However, will this effect further changes if they are made? Why is the <TITLE> not pulling a value from the model in the first place?
Message 10 of 23
mdavis22569
You can set it up to pull it all from the same spots ...
Question is how far do you want to go?  Also can you attach the part or a blank Ipt file of yours to show you
Mine is back populating the field box
you can make a prompted entry that will propulate it .... again it's all about how you want to set it up
Mike Davis
Message 11 of 23
mdavis22569
also as @mcgyvr pointed out you're pulling it from custom not Model
your title block should look like this  if you want it to be from the part
Mike Davis
Message 12 of 23
mdavis22569
you have
I've attached a sheet where I updated the title
Mike Davis
Message 13 of 23
mflayler
Have you read through this first (see attached)?  There are some tips here that will probably help you.
Off the top of my head, I think you should...
Not use Prompted Entries (especially if Vault is in your future)
Use an iLogic Form to fill out your Custom iProperties
Consider having model iProperties populate your drawing border as well as copying themselves to your drawing iProperties (especially if Vault is in your future).
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 14 of 23
I get an 'error in reading RSe stream' when I try to open the drawing...?
Message 15 of 23
mcgyvr
Do we assume thats on the drawing from mdavis?
If so.. it doesn't matter..
The point is that your template is simply not setup as you think it should be.. So fix it..
Message 16 of 23
Is there any way to trigger this 'retrieval of metadata' again?
Yes, I have fixed the issue. Thanks for your help. Does anyone know why the 'title' area was actually blank, or is this just one of those things?
Message 17 of 23
mdavis22569
sorry I'm on 2016....
anyway ...look at my pictures ..that's how you want to set it up to  look ...
model properties , title ....
same with any others that you're pulling from the model ....
Mike Davis
Message 18 of 23
mdavis22569
it was blank because NOTHING was in the custom title property on the IDW .....
when I manually put in ...HERE IS YOUR ANSWER .... it showed up
Mike Davis
Message 19 of 23
Your answers have been very helpful. Thank-you.
It is not normally blank when I do this. Is there any actual reason why this data was not collected?
Message 20 of 23
mdavis22569
not sure .... unless someone changed it to pull from the custom vs model
Mike Davis
