Title Block in Wrong Position
Hi I am trying to update the title block on drawings with a new one which is in our new drawing template. I used the Drawing Resource Transfer Wizard, all worked well apart from the title block appears in the top right corner on the drawings being updated. I have selected bottom right block insert in the options and it still does it. How do i get it back to the bottom right?
johnsonshiue
Hi! Could you take a quick look at the following posting and see if it applies to you?
https://forums.autodesk.com/t5/inventor-forum/custom-title-block-position/m-p/3506430#M439097
If not, please attach an example so forum experts can comment further.
Many thanks!
Software Test Engineer
MSD_takaseh
Hello jonty,
Can you check the [Edit Sheet] > [Orientation]?
Thanks.
Hitoshi Takase
It may do but I can't seem to get the tool to do anything? here is the example.
Thanks for that, got it sorted
