Threads not showing on rectangular pattern
chris91
chris91
I have a single row of six holes that I created using a rectangular pattern.  The holes are two inches apart.  The first hole (1.125 from end) displays nominally.  And the last hole displays nominally.  The threads though are not appearing in the center four holes.  the holes are 1/2-13 through holes.
I have deleted the array and reinserted; no joy.
I have not tried inserting them manually yet (after all, it is only 5 holes to insert), but still.  The other set of six holes are also inserted with a rectangular pattern.  They look fine.
Any ideas what is causing this and how to get around it???
Chris Breidenbaugh
INV 2025
chris91
I deleted everything, including the hole being patterned.  Re-inserted the pattern, and all was good.
