I wish to know whether it is possible change cosmetic thread into model thread by using ‘Thread Modeler Tool’ for the parts placed from Content Center. Because I am unable to do it.
Solved by CCarreiras. Go to Solution.
I am sorry my first question is incorrect. Correct question is:
Is possible to apply ‘Thread Modeler Tool’ to change internal cosmetic thread into model thread? Because I am unable to do it.
It's possible to apply the thread modeler into a custom content center part.
Aong others situations, Thread modeler is used in two main situations:
If you want to produce the nut or bolt, so you have to design the real thread.
If you want to make an animation between a nut and bolt with constrains.
The "real thread" is a complex shape and the part will become more "heavy", so is not to used to place in assemblys.
An assembly may have hundreds, thousands of bolts, if each one is a Heavy part, your assembly will turn in to a heavy and slow model...that's why the content center parts have an image instead the real thread.
Just don't change the content center parts for this one's...
Content Center parts placed as Standard go into the active project's designated Content Center folder. The active project's CC folder is treated as Read-Only, so no editing allowed. To get around this, something needs to change so that the part file is no longer in the active project's CC folder: either move the file to a different folder, or change projects to one with a different CC folder.
As CarlosC has already told you, placing CC parts as Custom allows you to choose the file location, presumably a folder that is not set as read-only.
Sam B
Inventor Professional 2017 R2
Vault Basic 2017
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
