Thread comand problem Inventor Professional 2016
Whe I try to run thread comand at 3D model tab, modify panel for the part's tutorial 2 step2, Inventor shows two errors attached in printings below. I tried to install mdac 2.8 from the link in one of the common issues in the support page of Inventor here, but it didn't solve the problem.
blair
Do you have Microsoft Excel installed and if so has it been run once for the EULA to be displayed and accepted?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
No, I don't have it installed yet. Installing now.
Mark.Lancaster
Also if you apply SP1 for Inventor 2016, threaded holes no longer depend on having Excel installed however things like iParts and iAssemblys will not function properly without Excel.
Mark Lancaster
Thanks you both, I solved the problem with Excel
