Thickening a Helical Surface Glitch
Hi, I encountered a bug that creates erroneous geometry when I thicken a helical surface. I first created a helical spiral 1 inch above a cylindrical solid, then projected the spiral onto the cylinder. I then lofted the two spirals two create a surface. When I thickened the surface, random erroneous geometry was created and I have no idea how it happened. How did this happen, and how can I fix it?inventor glitch.PNG
johnsonshiue
Hi! This is a bug. It means the thickened geometry is bad. It should not be. I notice that you are using Loft to create the helical surface. Could you tell me why you could not use Sweep along helical path instead? The geometry created by Sweep is more precise per definition.
Many thanks!
Software Test Engineer
Hi, I'm new to Inventor and didn't know that you could use sweep for this. I shall try sweep instead of loft and see if that fixes it.
johnsonshiue
Hi! If you could not figure out, please share the file here. Forum experts can help take a look and propose the best workflow.
Many thanks!
