There're no Custom Property Format feature?
travis.designer.vn
travis.designer.vn
Hi
When I select parameter SQ as below, there are Custom Property Format.
But with Long parameter, there're no.
Attached file inventor 2021.
Thank
Travis
johnsonshiue
Hi! It is because the parameter is not yet "exported" as a custom iProperty. Only the exported parameters have such options. Go to the Export column on the far right and check the box.
Many thanks!
Software Test Engineer
travis.designer.vn
Thank @johnsonshiue
You're right. I tick Export Parameter, they will show Custom Property Format.
Happy holiday John
