Hello!There is a problem with the Autodesk Inventor 2018 component library.The next time I created an Assembly,I wanted to insert a part from the component library,but the "Insert from component library" button stopped working, that is, the window with the parts stopped opening.I decided to open the component library editor, but it stopped responding,no Windows were displayed.At attempt of updating writes "in this Assembly there are no standard components".I would have thought I might have accidentally deleted them, but when you open the library settings, everything is in its place.And when viewing a folder, there were my standard parts.How can I fix this problem? P.S. This problem has led me to confusion as before everything worked perfectly.Maybe I could click anywhere and all the settings could go wrong.I tried to reinstall the program, but the problem never disappeared.
