I have a series of sketches which, when taken together, create a fully defined system. I would like to know the equation used to calculate the driven dimensions.
As a simplistic example, if my system were just a right angle triangle and I had set the dimensions of the two shorter sides, could I get inventor to tell me that the hypotenuse is given by sqrt(b^2+c^2)?
My actual system is significantly more complex than this and calculating the equations manually is stretching my trig abilities. I have attached the part file. I would like to know how the the three driven angles are calculated from my 8 set lengths and 3 set angles.
Thanks for any help.
