The operation is cancelled
0x3FA5
Message 1 of 9
0x3FA5
As per suggestion of the software, I am notifying Product Support of the problem, by posting to the Inventor forum.
Tried to rotate a part in an assembly.
I am experiencing an issue indeed, and hope the Product Support of the problem responds soon.
Replies (8)
Message 2 of 9
johnsonshiue
Hi! Many thanks for sharing the dialog! I am embarrassed to say this is the first time I see it. Are you able to reproduce the behavior? Is it file specifc?
Thanks again!
Software Test Engineer
Message 3 of 9
0x3FA5
Cannot reproduce unfortunately. This comes up absolutely randomly. It randomly appears if I try to rearrange items in the tree, or just trying to rotate a part.
No clue what can trigger that.
But the automatic suggestion to search for help  with a software issue on the forum is quite amusing 🙂
Message 4 of 9
johnsonshiue
Hi! Just a wild guess. Try cleaning up %temp%. Make sure all critical Windows updates are installed and graphics driver is updated.
Many thanks!
Message 5 of 9
0x3FA5
Yes, indeed, the temp folder is about 3.5 gb.
Deleted and will see if something changes.
Thank you!
Message 6 of 9
cosmin_andronic952G9
Hello, i'm experiencing the same issue. Did you find the solution for this?
Message 7 of 9
0x3FA5
Hi, yes, the solution suggested by johnsonshiue seems to work:
Message 8 of 9
rajivd
Community Visitor
Community Visitor
Also, I'm unable to trim a new line made in a fully constrained sketch.
Message 9 of 9
CGBenner
@rajivd
Welcome to the forum.  Are you experiencing an issue related to the original post above?  What version of Inventor are you using?
Chris Benner
