The .ipj file does not open Inventor 2020 with its project.
Malenki
Message 1 of 35
Malenki
I have had a problem for some time. I run a file, e.g. filename.ipj by double-clicking it in the Files Explorer  of system. Inventor opens, but with the project that was used previously instead of the project assigned to filename.ipj. The desired project can be set only from the Run menu (Projects icon) in the open Inventor instance. What happened suddenly? Can anyone show me how to fix this situation?
Help me please...
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K CPU@3.70GHz + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
Replies (34)
Message 21 of 35
SBix26
@Malenki wrote:
Thank you for the idea, but I didn't pass the exam.
Nevertheless, something touched me and I looked into the windows registry. The key branch [HKEY_CLASSES_ROOT \ Inventor.ProjectDocument \ Shell \ Open \ Command] contains a default value: "C:\\Program Files\\Autodesk\\Inventor 2020\\BinInventor.exe /pf \"%1\"". The problem is that there is no such file in my system (under the name BinInventor.exe). I get the impression that the last update removed it and this is the source of my problem.
Can anyone confirm this and possibly give me the BinInventor.exe file for Inventor Release 2020.1.1. (Build 239)?
The path you show is incorrect.  Bin is the folder in which Windows should find the Inventor.exe file.  The path is missing a folder delimiter.
Sam B
Inventor Pro 2020.1.1 | Windows 7 SP1
LinkedIn
Message 22 of 35
Malenki
No positive result. Thank you.
Message 23 of 35
Malenki
You are perceptive. I noticed that too. I have improved the path. However, it doesn't matter if it's backslash or not. The problem continues. Thanks.
Message 24 of 35
Malenki
I would like to inform you that after using the update 2020.2.2 everything has returned to normal and is OK :-). Thank you for the discussion.
Greetings.
Message 25 of 35
This update didn't solve the issue for me. I am still facing the same issue.
is there any way we can get it fixed?
Message 26 of 35
atinderghara
HI All,
I have found a solution to the problem, try InventorReset.exe in C:\Program Files\Autodesk\Inventor 2020\Bin, open your inventor it would have reset to default, now close inventor and reopen using IPJ file.
It would work now.
Message 27 of 35
CAmaral84
Community Visitor
Community Visitor
Thank you, thank you!
I was facing this problem since long time. I'm working with Inventor since 2007, and with multiple project, and I always starting openning the IPJ file!
Many Thanks!
Message 28 of 35
atinderghara
Glad i could help
Regards
Atinder
Message 29 of 35
ufficio_tecnico5
Observer
Observer
solution tested Windows 10 pro Inventor pro 2020
1°   open regedit
2°   go to the string
Computer \ HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Explorer \ FileExts \ .ipj
3° edit Computer\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.ipj\OpenWithList
a                  reg_sz   inventor.exe
b                  reg_sz    ab
c                  reg_sz    adbc
d                  reg_sz    a
e                  reg_sz    Ipj.exe
MRUList     reg_sz    abcde
4° edit
Computer\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.ipj\OpenWithProgids
Inventor.ProjectDocument  regnone    0000
end
or download attachment Ipj start inventor 2020.reg
by Ivan
Message 30 of 35
caroline_ccc
Also after resetting Inventor as proposed I had to go to the .ipj icon and change the properties to open with Inventor.
That worked!
Message 31 of 35
hamza_khan1
Hi, whenever I am opening any inventor project file i am facing this issue. Any solution? I tried almost everything.
Message 32 of 35
atinderghara
try resetting inventor.... it has worked for me
Message 33 of 35
D0UGLAS
I have this problem with the Release: 2021.1.2, what has changed?
How do I fix it?
Message 34 of 35
atinderghara
press windows key on keyboard and type inventor reset and rest your 2021 inventor...
Message 35 of 35
D0UGLAS
Thanks, but a reset does not solve the problem.
