Inventor Forum
The fillet issue
4 REPLIES 4
335 Views, 4 Replies
The fillet issue
Hi!
I am trying to make fillet for the back of the torso the same way I have at the front part
but I can't do that.
What do I miss?
The screencast is attached.
I have tried to upload the file, but I get the following error:
Correct the highlighted errors and try again.
The attachment's imantorso.ipt content type (application/octet-stream) does not match its file extension and has been removed.
Thanks!
4 REPLIES 4
JDMather
Zip file to Attach here.
If Edge Fillet does not work - then try Face Fillet.
in reply to: JDMather
Here it is
JDMather
If you zoom way in at the bottom of the back - there is some left over rubbish geometry here.
Edit Fillet2 and Ctrl remove that edge from selection.
Start a new Fillet and you can go up to about 2.5.
Thanks!
