- Mute
- Permalink
- Report
Would anybody like to take a look at this part and see if they can figure out the cause of this error? If you edit any feature, then click "ok" (even without changing anything on the feature), you'll get the error. There's some problem with updating the flat pattern. If I delete the flat pattern and recreate it, this problem goes away. If these were my own parts, I would recreate the flat pattern, carry on, and leave it to "Only the Inventor gods know what was causing that error." The problem is, these parts aren't mine. I wrote a plugin for some others that export parts out of inventor into a different software. When the code analyzes the part, it has to modify the part(same effect as editing a feature), thus causing the code to crash. I need some way to check the part for the error but I need to know what is causing it first. I'm using version 2023
