texture editor
texture editor
berry.lejeune
texture editor
berry.lejeune
Hi all,
Some of our customers require a render from our stones. But the issue what I have is that when I use the texture editor there's always a repetive pattern in the stones. Is there a way to completely randomize the pattern so we don't see the pattern like it is now and get a more real life structure of the granite.
I'm not really sure if you can see it in the attached picture. Our scale is 20cm/20cm and you can really see the lines of the pattern.
-niels-
To my knowledge, Inventor does not have a "randomizer" for textures.
You can either have a rectangular pattern or no pattern.
If a rendering is critical, i'd suggest switching to better rendering software, for instance 3DS Max has options to randomize textures.
If it's "not that critical" you could try creating a custom texture in an image editing program that you don't pattern, but make large enough to cover the entire surface and then randomize the content.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
berry.lejeune
I was already afraid that this wasn't possible. I'll give it a go to make a big picture with a lof of small rectangles through each other and try this way to come to a more realistic looking granite.
-niels-
Maybe some of the textures here can help?
http://texturelib.com/#!/category/?path=/Textures/rock/stones
Niels van der Veer
The Netherlands
Bill_Bogan1
If you look for textures to work with Inventor, try to get those that are "seamless".
It can be difficult to locate ones that really work well - I've looked hard and long at times.
Seamless have a less recognizable seam. It's still there if you dive into the image.
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
Autodesk, Inc.
