Text missing from exported pdf
Raider_71
Raider_71
Hi please see the idw and pdf attached. When the idw is saved as a pdf some of the text is missing. If I print the drawing to a pdf printer then all is there. Is this a bug?
Pieter
Nicolas.Bourquin
Dear Raider_007,
Thank you for having posted your question on the forum.
After investigation of the drawing, the problem seems to be due to a problem with the arial font used by local Inventor styles.
Potential cause: Texts corrupted in sheets 3, 4 and 5.
Observations:
  1. Problem with sheets 3, 4 or 5 when exported.
  2. No problem with sheets 1 or 2 when exported.
  3. All sheets exported at the same time (Export > pdf > option >All sheets > ok > save) => no problem
  4. Sheet 4 moved up at first position in browser > export all sheet (as in step3) => problem visible on all sheets of pdf.
Workarounds/Solutions:
  1. Change Text style > Current BSI > "Font" > Arial to Arial Unicode MS => pdf export is then correct.
  2. Copy all sheets from problematic drawing > Past in a new drawing generated from default template => depending the situation could solve the problem (not verifiable in this case because model files are not provided).
  3. As you mentioned, printing in pdf (using a 3rd party pdf printer) generates correct results.
I hope that will help you.
Best regards,
Please, hit the Accept as Solution button if my post answers your question.
Nicolas Bourquin
mcgyvr
Just print to PDF and forget you ever saw Inventors buggy PDF functionality.
