hello,
running into some strange text issues... fonts having problems and text not showing on the drawing that is in the text box. (shows fine whith out the bold option but does not when its turned on)
files attached should explain.
inv 2012
sp up to date
thanks
-ian
Please make sure whether all the fonts are available in your windows directory. If not, you can copy them to your C:\Windows\Fonts directory.The location on the media is \Inventor\x86\Windows\Fonts\Redist.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi
I get exactly the same problem - some of the text (or numbers) goes missing in my idw - not all the text.
No problem when printing to PDF - which means the problem is ???
Just installed Iv 2012 - same machine has been running Iv 2011 with no problems.
I cant see any solution here?? Please help.
Vh Ebbe
Solved the problem.
I just removed the new and fancy - and instead went for "Use Classic Context Menu" (Customize + Marking Menu)
Vh Ebbe
