@p.keizer wrote:
In my part I extruded a text with a text height of 200mm.
When I measure the text there is a difference between the heights of the letters.
What can I do about this problem? I mean a text height of 200mm should be 200mm for every letter right?
Blame the creator of the font..
Letters are not always the same height..
You can see that in Word too so its not just an Inventor thing..
If you need them to be exactly the same then maybe find another font that has them consistently the same height or each letter needs to be its own piece of text so you can adjust each letter accordingly..
