How to extrude a 3D Sketch
BjarneVanBuggenhout
Message 1 of 10
BjarneVanBuggenhout
I have got a 3D sketch into my cilinder...
Now is there a way to cut away to upperside of the cilinder, so i have the spline waves cut out?
Accepted solutions (3)
Replies (9)
Message 2 of 10
Cadmanto
It looks to me like you could create a surface using the 3D sketch, then create a sketch above them and extrude cut to these surfaces.
Hope that makes sense.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
jtylerbc
Another option might be to create the surface as @Cadmanto described, but then use the Sculpt command and select the surface as the cutting tool, instead of using an extruded cut.
This would eliminate the need for the extra sketch he mentioned, while giving the same end result.
Message 4 of 10
leowarren34
I believe that if it is uniform than create a solid and split it along the spline using it as a path.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 5 of 10
johnsonshiue
Hi! Adding to Scott's and John's comments, you can also use Rule Surface command and select a direction to "extrude." Result is a surface based on the 3D profile sweeping along the direction in a given distance.
Many thanks!
Software Test Engineer
Message 6 of 10
Three methods come to my mind right now.
All start by creating a surface from the 3D sketch with "Patch".
1: extrude from a 2D sketch below, extent "To" -> select surface... or if an existing solid goes through, do the same with extruded cut
2: If an existing solid goes through, use "Split", pick "Trim Solid", then select the face as "Split Tool".
3: existing solid below or above: Click "Replace Face", select your flat cylinder face as "Existing Face", then the surface as "New Face".
Message 7 of 10
BjarneVanBuggenhout
This was very helpfull,
but I didn't got it quite right...
Knipsel.PNGI want to make te cut "straight", like this:
If i want to cut to this plane, I've get a failure:
Message 8 of 10
johnsonshiue
Hi! The error might be due to the surface being smaller than the solid. Try using Extend command to extend the surface further (inner and outer loops). Make sure the surface covers the solid body.
Many thanks!
Message 9 of 10
BjarneVanBuggenhout
still the same error...
Message 10 of 10
BjarneVanBuggenhout
It worked, I used the split command instead of the extrude command!
Thanks for the help!
Kind regards,
Bjarne
