- Mute
- Permalink
- Report
When I create centered text in a sketch and center the text on a feature, then use the Mark command to create single-stroke geometry for engraving, the text does not remain centered. In the attached screen grab "Mark command letter shift", the red letters are the centered text of the sketch, the black letters are the result of the Mark command. It appears the the Mark command begins at the left edge of the line of text and just letters to the right, no center justifying is done. I tried adjusting the stretch of the text the sketch text, but the resulting text from the Mark command is also adjusted. The font used for the text in the sketch and for the mark command are the same, in this case romans. In the screen grab "Typical connector panel", an example from a past project using the Emboss command, the goal is to center the lettering under the connectors. The shift from the Mark command makes the lettering off.
Is there a fix here? Thanks.
Gordow
Inventor 2023.3.1
