Text Convert to Geometry in Inventor 2017 R3 release
Rob67ert
Message 1 of 11
Rob67ert
Maybe i'm missing something, but now you are able to convert text to geometry, this is great.
But what can you do then?
Not able to extrude it, so it will not be visible in the part.
And in Sheet Metal you can place text in the flat pattern and also convert the text, but it is not visible in the dxf.
So what can we do with this new feature?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Replies (10)
Message 2 of 11
CCarreiras
HI!
Don't use extrude to "mark" the part or flat pattern with text, use EMBOSS tool instead and it will work.
CCarreiras
Message 3 of 11
Unfortunately that also does not work.
There are after a convert a lot of open loop's in the sketch.
Message 4 of 11
CCarreiras
You don't need to convert the text.
Use EMBOSS directly in the text
CCarreiras
Message 5 of 11
Rob67ert
Sorry, my mistake.
But i like to use it for laser engraving, an extrude or emboss is not the ideal option for it.
Robert
Message 6 of 11
mcgyvr
Works fine here..
Create your sheet metal part..
Create the flat pattern and then add the text to it in the flat pattern and then convert that text to geometry ..
Then right click on the top flat pattern node in the model browser and click "save copy as" and create your dxf file..
Open in Autocad and text is shown..
Message 7 of 11
SašoPrijatelj
if you need the text for laser engraving then Exploding text to geometry is exactly what you need. If you want to include the text in exported flat pattern you'll have to turn on Unconsumed sketches layers in set its color during saving to DXF.
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 8 of 11
Rob67ert
Yes that works. The way i made an export to DXF was with iLogic.
But......the number I like to place on the part is the part number.
With iLogic i place the part number as text on the flat pattern. We work a lot with derived parts for a left and right copy, and in that case the ilogic works.
But if I use the convert, the connection to the original text is broken.
Robert
Message 9 of 11
SašoPrijatelj
Yes, that right. I think there is currently no way to parametricaly drive converted texts.
Message 10 of 11
rickER9UF
Is there anyway to do this conversion in inventor 2014?
I have a embossed text on a part and looking to get the file size down
Thank you
Message 11 of 11
Rob67ert
Inventor 2014? I guess not, we have Inventor 2019 now and still no solution.
Robert
