Hello everyone,
In a text box or dimension editor, is there a way to type in subscript?
I know there is a way if you go to the Character Map and find the right font. But that will only let you uses numbers in the subscript. I would like to be able to type anything I want in subscript.
Thank you for any help that you might be able to give.
JD
Solved by rAYMONDP2ZF3. Go to Solution.
Sorry..
To superscript subscript type ^<information>
To subscript superscript type <information>^
Highlight that text including the caret (^) and right mouse click and select "Stack"
Because: Stacking triggers are: / (solidus), # (number sign), and ^ (circumflex accent).
the # is used to generate the / for fractions.
