Inventor Forum
Text box size issue
10 REPLIES 10
Message 1 of 11
777 Views, 10 Replies
Text box size issue
I am having an issue entering manual text sized in autodesk inventor. please see the image to see the issue i am having. As you can see, the box used to enter the size part shrinks down to nothing when i enter a size.Inventor issue.png
10 REPLIES 10
Message 2 of 11
johnsonshiue
Hi! I vaguely remember the issue was discussed before, though we could not reproduce internally. Try using Inventor Reset Utilities (All Programs -> Autodesk -> Inventor 20xx -> Tools -> Inventor Reset Utilitied). It will reset all Inventor settings back to install default.
What is the screen resolution and DPI setting?
Many thanks!
Software Test Engineer
Message 3 of 11
in reply to: johnsonshiue
Unfortunately, that did not work. computer is a lenovo p1 with a 4K display running windows 10 pro. I do not know the DPI of my computer. Hope this helps!
Message 4 of 11
johnsonshiue
Hi Craig,
This issue was reported as INVGEN-29561, which has been fixed on 2020.1 update. You are probably on 2019 or 2018. The fix is not yet available there. I will need to check with the project team and see if it can be ported back.
Many thanks!
Message 5 of 11
I am on 2019. I have never had this issue anywhere else. And if it helps, I first downloaded the 2020 version, but I had the same issue so I downloaded 2019 and it was not any better.
Message 6 of 11
MoshiurRashid
Have you rested your inventor? I think it should work
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 7 of 11
johnsonshiue
Hi Craig,
As I mentioned, the issue has been fixed on 2020.1 update. Please install 2020.1 update and report back your findings.
Many thanks!
Message 8 of 11
Thank you so much. The 2020.1 update fixed all my issues. Your help is greatly appreciated.
Message 9 of 11
teepee11
Still happening
Message 10 of 11
rhasell
Hi
What is still happening? I suspect your issue is different from the OP.
Based of your screen captures, hold the CTRL key and use your mouse wheel to change the scale of the text box.
Reg
2025.1.2
Please Accept as a solution / Kudos
Message 11 of 11
teepee11
in reply to: rhasell
Thanks, this is the solution I was looking for. Simple when you know.
