Text background is not working on rotated text
CBhavsarW8SYW
Message 1 of 8
CBhavsarW8SYW
Apparently, background filling in text in drawing environment seems do not rotate with text, it stays horizontal.
Replies (7)
Message 2 of 8
CGBenner
@CBhavsarW8SYW
Hello, what version of Inventor are you working with?  Can you share exactly how you rotated the text?  What was the workflow?  Examples of what I am seeing in IV 2024:
As Created:
Rotated 30 degrees in the Text Editor:
Chris Benner
Message 3 of 8
CBhavsarW8SYW
Hi @CGBenner
work flow:
1. Start skecth in drawing.
2. Insert text & apply background color
3. 'Rotate' text using 'Modify' toolbar pallet.
4. Text rotates but not the background color.
Using 2025 Inventor (2525.3.1)
You are right, in normal text command under 'annotate' it works as you have shown.
The main reason of using sketch to insert text because I do not want text to fly every where when I move the view, I am constraining it to the view to achieve this but apparently the background color does not rotate with it.
Hope this makes clear to you.
Message 4 of 8
SBix26
I see the same behavior in Inventor 2026.1
If I turn on Text Box, it's easy to see that the background is simply a 2-point rectangle from lower left to upper right corner of the text with no regard for the orientation of the text:
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
Message 5 of 8
CGBenner
@CBhavsarW8SYW
Thank you!  That explanation makes it much clearer.  I'm going to tag @johnsonshiue to seek his feedback and advice on this one.
Also, thank you @SBix26 for sharing that you were able to reproduce this.
Chris Benner
Message 6 of 8
dan_inv09
Are you not able to use leader text and delete the leader?
Message 7 of 8
johnsonshiue
Hi Folks,
This one looks like a bug to me. I need to work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 8 of 8
johnsonshiue
Hi! The project team has confirmed the behavior and it has been reported as INVGEN-86266. Please feel free to contact Autodesk Product Support to escalate a fix.
Many thanks!
