So I was thinking about optimizing my workflow and want to create some templates from parts, assemblies, and drawings that I often use in as a base the model from. Templates from parts seem to be no problem, whatever I do there will be in the template. The problems start when I want to create a Template from drawings, When ever I do that the part or assembly that orriginally was on the drawing will not be included when I use that template. I tried to save the part in the same folder but same thing, an empty drawing.
I assume a Template of an assembly will act in a similar way?
is it possible to create templates that includes/copies the parts and/or assemblies that are used in the original drawing, so that when I use that drawing template the parts and/or assemblies will also be created and included as new parts/assemblies.
At my previous work they had something like this so I know it is possible in some way but they had a **** load of addins. So the actual question is, is it possible without needing addins?
Solved by Gabriel_Watson. Go to Solution.
Hi!
Yes is possible.
You can create those templates (views, etc) and they will be available here:
(When you create a new drawing file)
Or here, when is already open:
To create the template, set the views you want and:
This is very useful thanks, but this creates a (new) sheet that is set up in a certain way with an already made part. I wanted to make a template of a assembly and/or drawing that makes a copy of the parts and assemblies used the the in the assembly/drawing whith which I created the template.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
If you don't have Vault, you can use "iLogic Design Copy". Uses similar process as Vault.
