TEMPLATE STYLES
TEMPLATE STYLES
CKendall745ST
Observer Observer
TEMPLATE STYLES
CKendall745ST
Observer
Observer
Im currently getting our company set up in Inventor and im curious if there is a way to set up a template with multiple styles definitions. For example id like to start a new drawing based off a template, then inside that template have 4 different sheet selections on the left ( ANSI A,B,C,D) all with their own title blocks (i figured this part out see snip below) and each with their own style definitions (this part i cannot figure out) when i open the template all sheets have the same text heights and leader sizes but clearly text height and leader size for an A sheet and D sheet are very different. Example my Dsize text height is .25 and my A size is .1 and id like to have a different style definitions for each sheet if possible.
Gabriel_Watson
You can't simply copy a titleblock if you want to change the style of text within it. You will need to copy the title block but delete the text boxes and re-create them again to pick on the top-left corner of the "Format Text" window which text style you wish to use (and those need to be local to your file, so you have to update your file with the styles you need if they're not there yet).
