Has anyone got an answer to this. I have created a multi body ipt file. I go to Make Components, the template box is empty so I search the template which I have used. Notice the Template column is empty on the next screen, I press Apply and get this message. I don't know what I have done wrong?
Solved by SharkDesign. Go to Solution.
@vasN5QQD see this thread: 2022.2 Make Components : Selection Dialog not working - Autodesk Community - Inventor
(assuming you have upgraded to 2022.2)
Uninstall the Inventor 2022.2 update (roll back to previous version) and it should work. Issue marked as INVGEN-57952, if you follow these to see when fixed.
I don't think this is related to the 2022.2 update. You don't get to see that screen in that particular bug.
If you double click the template white box does it give you some options?
The reason it is white is because you don't have a template called 'standard.ipt' you probably renamed them when you customised your setup. Clicking the white box should show you the other templates you have.
p.s. if you shift select all the rows and then click the white paper icon above that column you can apply a template to all of them at once.
