Inventor Forum
Tee Enclosure
2 REPLIES 2
133 Views, 2 Replies
Tee Enclosure
See Customer files same subject. When added as the first component in an assembly, I get the error "Failed to save factory member". This is an iPart and works fine in part mode.
2 REPLIES 2
I think it may be because you have no keys defined.
Make your description a key and see if it works for you. This is what I changed
and it worked for me. You may also want to define a filename
column.
Byron Newton
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
See
fine in part mode.
Thank you Byron, it's always the simple things....
The key on the description field solved it.
