Hello ๐
I'm in the middle of writing a load of blurb on one of my drawings, but for some strange reason the technical requirements dialogue box wont accept all my information in one go. Looking at the forums I see that there is a setting for changing the amount of lines you can have in the box. However I cannot see the settings tab within the ESKD tab (see below).
Ribbon: Annotate (ESKD) tab Format panel Technical Requirements Settings (not visible on my toolbar).
Any Ideas?
Kind Regards
Jason
Solved by Mark.Lancaster. Go to Solution.
I've never really used Tech Requirements but I don't recall seeing there's a limitation.. Can you specify the link where you found about this?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Mark Lancaster
must have been the only button I didn't click, its not really that obvious.
Many thanks Mark
Kind Regards
Jason
Hi Jason,
This dialog does have room for improvement. The behavior is not as intuitive as it should be. To access most of the buttons at the top, you will need to click on "Technical Requirement" folder in the tree view. Once you select the sub folder, the buttons become disabled.
Many thanks!
