Task Scheduler not scheduling
Nicht anwendbar
1.693Aufrufe
15Antworten
Nachricht 1 von 16
Nicht anwendbar
I've used TS ever since I can recall, never had too much issue.
But of late I've mainly used it as "Immediately", haven't actually had the need to set a time for a process.
But now I do and it's not working.
It'll take the schedule for the process but when the time comes, nothing. All it does is change the "Next Run Time" status to "Never", but the "Status" stays at "Scheduled".
This is for checking out a file from Vault.
So I do the same process but select "Immediately" and it works fine.
Set the schedule to check that file back in, nothing.
I have a massive process that I need to schedule, I need this to work.
Any advice?
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (4)
1.694Aufrufe
15Antworten
Antworten (15)
Nachricht 2 von 16
andrewdroth
Any chance the password for the user changed?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Nachricht 3 von 16
Nicht anwendbar
Nope, it's the same one I've always used.
Good point though
Nachricht 4 von 16
Nicht anwendbar
BTW - I've sent this on to Adesk, have a tech on it as we speak.
He too is having these same issues.
Updates coming.
Nachricht 5 von 16
andrewdroth
Yep, I just tried to schedule a check-in and nothing happened. That's bad.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Nachricht 6 von 16
Nicht anwendbar
Exactly....not good for a "scheduler" that doesn't, well...schedule
Nachricht 7 von 16
andrewdroth
Yeah, like you I usually use "immediately", but for others that need it working in the background, well...
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Nachricht 8 von 16
johnsonshiue
Hi Guys,
I don't recall we change the behavior here. I suspect it might be Windows security related. Try this. Run Task Scheduler as Admin. Does it work now?
Many thanks!
Software Test Engineer
Nachricht 9 von 16
andrewdroth
Akzeptierte Lösung
I ran it as administrator, and I can see it opened a dialog and tried something, but afterwards the file still wasn't checked-in.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Nachricht 10 von 16
andrewdroth
Akzeptierte Lösung
Nevermind, It's because it was checked out to me on a different machine. That's always confusing.
Looks like running as administrator did work.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Nachricht 11 von 16
Nicht anwendbar
I'm attempting to run as admin but either I have massive lag time in the process or there's something wrong as it will not allow me to select the needed check boxes shown below (typically these are autoselected I thought)
***Nevermind*** Operator error as always...lol
Nachricht 12 von 16
Nicht anwendbar
Akzeptierte Lösung
Yeppers! I can validate, Running it as Admin does indeed work for scheduled processes.
Nachricht 13 von 16
Nicht anwendbar
Slight problem....running a scheduled Check Out as an Admin does work, but running a scheduled Check In does not!
Ugh
Adesk, can we get some help here?
****Hang on.....it just dawned on me, TS never requested to log into Vault nor ask for my password as it does for Check Out. Re-running the task...Update in a minute***
***Update - Nevermind, it does indeed work. I'd like to know why it didn't prompt me the first time for my Vault credentials. All's good.
Nachricht 14 von 16
Nicht anwendbar
Another wrinkle for the scheduled Check In process.
Each time I run the process, it fails and kicks an error that Inventor needs to re-register.
Ugh!!!!!
Nachricht 15 von 16
Nicht anwendbar
Found the failure cause...it fails in the process of creating a dwf file.
So if you do like we do and have dwf files being created at check in, this process seems to fail.
Now I just need to figure out if we in fact, need to have dwf created at check in as opposed to release state change.
Nachricht 16 von 16
Nicht anwendbar
Akzeptierte Lösung
OK, so here's a summary of being able to schedule a task in Task Scheduler.
Performing a Check Out of files (using Vault):
1. You must open Task Scheduler as "Run as Administrator"
2. You can only select one file at a time. You cannot use Shift or Control keys to multi-select
3. When selecting numerous files, the Select File from Vault process resets back to the root level and thus you'll need to re-navigate back to the active folder you are working in. Very time consuming if you have a lot of files to select
Performing a Check In of files (using Vault):
2. Unlike the Check Out task, this one allows you to multi-select using the Shift or Control keys
3. If you have Vault auto-creating visualization files on Check-In, this option must be disabled manually at the Check In Files state by selecting the Settings button and de-selecting the check box for such
