I'm working in Inventor\Task Scheduler 2024.1
I was logged into one Vault server in order to complete a task. I was then give a different task in a different Vault server, so I logged out of that Vault server and logged into the new Vault server. I went to check in the files using Check into Vault task and it failed completely. I check the logs and they said I didn't have any files checked out. I double check the new Vault server and I did have files checked out. So I checked Task Scheduler and the log in had reverted to the old Vault server.
I logged in to the new Vault server again, reran the task and it failed again for the same reason. No matter what I do, Task Scheduler will not stay logged into the new Vault server.
So now I have a computer user Task Scheduler on.
double check which project file task scheduler is setup to use. Sounds as if it's still using the previous project file.
HTH
