Inventor Forum
Tapered pan won't unfold correctly.
5 REPLIES 5
Rickpage76
315 Views, 5 Replies
Hi, Can anybody explain why this simple tapered pan will not unfold correctly? The flat pattern should only have 1 tapered vertical line. I believe I've constrained everything correctly & in the 3d model it looks fine. Thanks
5 REPLIES 5
IgorMir
in reply to: Rickpage76
Hi Ricky,
The flat pattern is correct, as far as I can tell. To reorient it - use Edit Flat Pattern Definition tool while in Flat Pattern mode. To see the effect of it - change the dimension 196 to something smaller, say - 100 mm. Then it will become more obvious what's going on.
Cheers,
Igor.
Web: www.meqc.com.au
Thomas_Savage
Hello @Rickpage76
I have attached a screencast of what i think will solve your problem.
You wanted it to flat pattern with one tapered horizontal line. So i placed a horizontal constrained on the horizontal edge, and not the tapered edge.
I attached the screencast so you can see how to do it easier.
Is this what you wanted?
Thomas.
Thomas Savage
Design Engineer
Rickpage76
in reply to: Thomas_Savage
Thanks Thomas for the answer, I couldn't figure why the taper seemed to carry on into the flanges.
Adding the constraint on the flat pattern works fine.
Thanks for taking the time to do the video
Rick
Rickpage76
in reply to: IgorMir
Thanks Igor for your help.
Rick
Thomas_Savage
Hello Rick,
You're Welcome.
Thomas.
Thomas Savage
Design Engineer
Technology Administrators
