Hi, I need work on Inventor, but when I´m creating a new assemble, the tab "design" isn´t active.
How can I activate it?
Try to reset your Ribbon (right-click the ribbon and pick the following):
If that does not work, attempt an Inventor Reset (Start Menu > Autodesk > Autodesk Inventor 2021 > Inventor Reset Utility).
@ej.bonilla
I'm confused. In your image, you have not yet completed the "New" command to create the new assembly, and I see the Design tab waiting in the background?
Did your question get successfully answered? Then just click on the 'Accept solution' button. Thanks and Enjoy!
Chris Benner
Thanks for your answer, but I did it and Still not working.
Hi! When you start from an empty assembly, within Frame Generator section, only Insert Frame is enabled. You need to insert a part with a sketch or body geometry and save the file. Then select the geometry to create the frame members.
Many thanks!
Yes, thanks for the information, I was not aware of that!
